Phaneks Enhoo 719 - I/O Panel - D-RGB Fan - M/B D-RGB 3 Pin Cable
13 Jun 2007
Dorset
Just bought a Phaneks Enhoo 719 These two cables from the I/O Panel: D-RGB Fan and M/B D-RGB 3 Pin. Should they both be connected to the motherboard (Asus x299 Sage)?
Only this one goes to the motherboard ;)
Think the other one for connecting more RGB accessories to (like RGB fans or RGB light strips)
I have an Evlov X case which has the same connectors
Yes my Evolv X came with a fan hub
I used to have the HUB plugged into the motherboard chassis fan 3 header but i now have it plugged into the external fan header on my GPU so the fans connected to the HUB are controlled by the GPU heat
My two CPU fans are plugged into my motherboard CPU fans header (there not connected to the Fan Hub)
You can see the wire from the Fan HUB plugged into the end of my GPU in this picture
Thanks..
