Phanteeks Enthoo Pro - simple one on reset switch wires
20 Jul 2007
A sunnier or damper area than Ron-ski....
Hi folks,
Just building a new pc this morning and really impressed by this case so far.
Just fitting the motherboard wires and installing the front panel connectors - daft one, for the two pin wires like the reset switch, the plug doesn't have a + or - on it like I've seen in the past, so just wondering how I know why way round to install?
Ok, think I've worked this out as I'm using the little triangle marker and assuming that's positive.
Now my challenge is how I connect the pwm hub.
I 'think' I need to connect my CPU fan to the pump 1 fan, because the hub needs to connect to the CPU fan slot on the motherboard - does this seem sensible???
Doesn't really matter on that switch. But yes the little triangle indicates positive.
As for the fan hub, yes that's my understanding. Luckily my motherboard has a CPU and also a CPU OPT (optional) fan header so I could attach both. But if it doidn't have that, then I would probably have tried the CPU fan header on the CPU headsink and a system fan header on the fan hub.
