Phanteks case screws missing help..
Permabanned
11 Jan 2019
bedlam
Good morning, i have received a new evolv itx case and the fitting kit is missing the extended screws needed to mount fans in the front.
What size screw are they. Am not going to rma a case over 8 screws, and I don't 2ant to wait 8weeks for phanteks to send me some
The length is 30mm but I do t know the thread type
I have a load of spare screws bud, one load of Phanteks screws very sizes, if you can get a pic of the one you need I could possibly help you
I contacted Phanteks for the screws, as I have the EVOLV ITX case, I contacted them a month ago, they did reply after a week and send they would send the screws, but I'm still waiting.
I also contacted Phanteks America, to see if they could help and they said I needed 6-32 x 31mm screws, which I couldn't find in the UK.
Nearest I could find were these radiator screws.
https://www.overclockers.co.uk/xspc-radiator-fan-screw-6-32-30mm-16pcs-bag-wc-40y-xs.html
I tried them and they seem to do the job.
If Minibiker is willing to help you out that would be great.
