** PHANTEKS EVOLV ITX - PROOF THAT AWESOME COMES IN SMALL PACKAGES **
I wouldn't call £35-£40 spitting distance. £40 extra buys you a lot more case. Personally I think Phanteks quality for around £50 represents excellent value. Out of interest I have the Phanteks Evolv Gunmetal and at £90-100 it represents amazing value too.
I made it only £9 difference (£55 itx case + £13 fan hub + £13 fan VS £90 mATX case). In essence I do agree £55 is excellent value for the case, it's just in comparison to the mATX Evolv (unnecessary imho) compromises were made in the accessories supplied, even ignoring the build material.
+1
I have the micro black version and what you get is something incredible!
So, 2 bits of good news for any prospective buyers of this excellent case (which recently won the 'Worth Buying' Award at Kitguru)
1) Stock is due to arrive earlier than expected, this coming Friday to be precise.
2) From Monday 9AM till Friday 9AM, I will be reducing the pre-order price by £5 on both models as a bonus for any forumites, making this already well priced case an absolute steal! :)
As promised :)
Phanteks Enthoo Evolv ITX Mini-ITX Chassis @ £44.99 inc VAT
Big on features and small in size, the Enthoo EVOLV ITX is a budget oriented chassis that uses a metal exterior. The case introduces a new unique bracket solution for mounting a radiator on top and a multifunctional bracket for reservoir, pump, and SSD/HDD.
Features
- Metal exterior (powder-coated steel)
- Clean and Compact design
- Clean interior - Hidden PSU and HDD’s
- Equipped with Phanteks’ velcro cable ties
- 28mm cable management space
- Additional cable compartment in bottom
- Comes with 1 x Phanteks PH-F200SP 200mm fan
- Supports 212mm PSU
- Supports 330mm VGA Card
- FRONT I/O: 2x USB 3.0 / HEADPHONE / MIC / RESET
- 1X SSD bracket included
- Offset Radiator Brackets: No conflicts between radiator and memory
Specification
- Dimension: 230 mm x 375 mm x 395 mm (W x H x D) - 9.1 in x 14.8 in x15.6 in
- Form Factor: Mini ITX tower
- Material(s): Steel plates, Plastic, Steel chassis
- Motherboard support: Mini ITX
- Front I/O: 2x USB 3.0, Mic, Headphone, Reset
- Side window: No
- Expansion slots: 2
- Internal 3.5”: 2x (1x extra upgrade slot)
- Internal 2.5”: 1x (1x extra upgrade slot)
- Front: 2 x 120mm fan, 2 x 140mm fan, 1 x 200mm fan (included)
- Top: 2 x 120mm fan, 2 x 140mm fan
- Rear: 1 x 120mm fan, 1 x 140mm fan
- Front: Up to 240mm radiator
- Top: Up to 280mm radiator
- Rear: 120/140mm radiator
- Up to 330mm VGA Card
- Up to 200mm CPU Cooler
Was £49.95 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Phanteks Enthoo Evolv ITX Mini-ITX Chassis with Window @ £49.99 inc VAT
Features
- Front I/O: 2x USB 3.0 / Headphone / Mic / Reset
Specification
- Side window: Yes
Was £54.95 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
