- 26 Nov 2014
- Stoke
** PHANTEKS EVOLV SHIFT-X & SHIFT - GET SHIFTY **
You'll be happy to learn that the Phanteks Evolv Shift-X & Shift are finally available for preorder! Originally unveiled at CES as the Project 217, the Evolv Shift-X & Shift aim to offer an innovative set of features wrapped up inside a lovely aluminium and tempered glass chassis that wouldn't look out of place in your living room. Both are Mini-ITX form factor, but are aimed at different user requirements.
The Shift-X is the premium model, with support for 280mm radiators, 529mm VGA cards, SFX-L PSU's and up to 4 x 140mm fans (of which 2 are pre-installed). There's sufficient space for a watercooling setup with a pump mount included, and theres a reversible GPU bracket and PCI-E riser cable to allow you to mount the card whichever way you would prefer. There's space for up to 4 x 2.5" SSD's, and if you sacrifice the radiator spacing you can also install a pair of 3.5" HDD's. Finally, both vents are made from aluminium and feature dust filters to keep your system clean!
The Shift on the other hand is a more cost effective solution with a smaller footprint. Space for the radiator is lost, along with VGA card length, although you can still fit a 120mm AIO & and 350mm VGA card in there. The reversible GPU bracket & PCI-E riser cable are included though, along with a 140mm front fan. SFX-L PSU's are supported as standard, and whilst the vents are plastic, the rest of the case is the same aluminium and tempered glass used on the Shift-X.
Both models support RGB lighting as you can expect and are compatible with Asus Aura, Gigabyte RGB Fusion and MSI Mystic Light Sync as standard. Both Black & Gunmetal Grey are available, and stock is due to arrive near the end of August. I would preorder as there is a huge amount of interest around these cases.
I'm going to be honest, I absolutely love this case, the Shift-X in particular. I've been keen on it ever since it was announced and seeing it in the flesh has convinced me to make it my next build case. I've been thinking of putting my system under water for some time now and this case is the one I'm going to do it with, despite the wallet destroying move from X99 to Z270 alongside all the kit I'm going to have to buy! Good job I work here...
Phanteks Enthoo Evolv Shift X Mini-ITX Tempered Glass Case - Black @ £149.99 inc VAT
Premium Mini-ITX Enthoo Evolv Shift X in Black, Aluminium panels & tempered glass, Good watercooling support & 2 pre-installed fans, Space for 52 cm long graphics card & 280 mm radiator.
Only £149.99 inc VAT.
ORDER NOW
Phanteks Enthoo Evolv Shift X Mini-ITX Tempered Glass Case - Gunmetal Grey @ £149.99 inc VAT
Premium Mini-ITX Enthoo Evolv Shift X in Gunmetal Grey, Aluminium panels & tempered glass, Good watercooling support & 2 pre-installed fans, Space for 52 cm long graphics card & 280 mm radiator.
ORDER NOW
Phanteks Enthoo Evolv Shift Mini-ITX Tempered Glass Case - Black @ £104.99 inc VAT
Premium Mini-ITX Enthoo Evolve Shift in anthracite, Aluminium panels & tempered glass, Space for 35 cm long graphics cards.
Only £104.99 inc VAT.
ORDER NOW
Phanteks Enthoo Evolv Shift Mini-ITX Tempered Glass Case - Gunmetal Grey @ £104.99 inc VAT
Premium Mini-ITX Enthoo Evolve Shift in Gunmetal Grey, Aluminium panels & tempered glass, Space for 35 cm long graphics cards.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
