Phanteks Evolv X2
14 Nov 2005
Just seen the below video, the new Evolv looks interesting, seems Phanteks are also bring out water cooling components that do not require fittings and will accept soft and hard tube. Second video shows the water cooling parts
I’m 100% buying one of these I think it looks absolutely stunning.
My only criticism is I think it needs an integrated GPU support off the side of the motherboard tray (so it’s mostly invisible) and that the glass was wrapped around as one piece, but neither are a deal breaker.
I was wondering about the GPU support myself, definately nmeeds to be something integrated and discrete to keep the aesthetic
I recently bought a Lian Li bracket that mounts to the motherboard screws, totally hidden, perfect in this kind of scenario. Last thing you want is an ugly GPU bracket through all that glass.
I really like this case but prefer my GPU to be vertically mounted rather than horizontal which would probably break the overall look.
One of those CPU blocks that feed the coolant through the motherboard holes would look brilliant in a case like this.
Got a link to that bracket? Might be worth looking into.
I can’t say where to get it although lots of places seem to sell them.
It doesn’t look much but the good thing is it’s almost entirely hidden once fitted you can’t even see it, fits my X670E Crosshair perfect even over the covers on the motherboard and holds up a big heavy Nitro 7900 XTX no problems. Their product pictures show it on the central mounts but I used it on the mounts on the right side no problem instead.
Ooh right, i thought it was a hidden vertical mount.
i have i thread about the fittings
its in watercooling section
short explanation
to use soft tubing you must use inserts in the tubing
