**PHANTEKS GLACIER WATER COOLING RANGE IS NOW AVAILABLE FOR PRE-ORDER**
Thanks. Much appreciated. Looking forward to placing my order if in stock :)
Found the issue. It shows the correct stock level when using desktop version but preorder on the mobile.
We have 9 units left of the 1080 strix black and 9 of the chrome version.
I think going off reviews the EK edge it by a degree or 2 but the phanteks has better flow rate and has the added RGB features if that's what you are looking for.
do you know if they have plans to do AMD gpus? maybe not the rx 4/580 but the next set?
They may look at vega but AMD has not been a success in the water cooling market unfortunately but that could be because the cards do not get that hot.
At the moment phanteks have not mentioned any AMD GPU blocks.
