Phanteks Luxe
7 Jul 2008
Hi all trying to connect the Phanteks Luxe case cables to my x99 motherboard. connected USB 2 & 3 cables along with HDD LED light. But struggling to figure out where rest of cables go. according to manual my motherboard has slot on motherboard for Reset but I actually have 2 x 2pin cables for reset? any help? I don't seem have a cable for power button
I the case should have those really slim wires for the reset and power. That connect to the pins of a motherboard.
I'm guessing one was meant to say power. You could hook them into the power + reset pins on the mobo, and try switching on with the switch on top of the Luxe. If nothing, try switching the pins around.
That is meant to indicate H.D.D LED & Power SW. But I/m guessing they labelled it wrong. That reset with the h.d.d led is indeed the power cable.
Because I have the same case. I just opened up mine and had a look. The hdd is attached to the power.
Tried to find the LED - and + too, but couldn't find those, it's only from what I read in the manual.
