Phanteks Neon RGB
27 Mar 2016
Bristolian living in Swindon
Hi all
So I built my new PC today but feel there is not enough light inside the case...
I've ordered the Phanteks Neon RGB strips 2x 400mm, they have a 3pin 5v connection however my motherboard has a 4pin 12v connection, is it OK to plug them into that header?
Cheers
Ahhh balls :p ill cancel my order then
Do you have a phanteks case?
My luxe2 /719 the strips can be added to the case leds
Even if you get standard 12v phanteks leds you need the 5 quid adapter to connect to motherboard 4 pin
I've just looked into all this for a new build and it is just not worth the hassle.
Yeah need to plan it because of the 5v and 12v thing
Plus all the makers using proprietory connectors too which is a pita
I have the Antec P120 case, I thought it would be OK going to that header, good job I checked, think I'll have to find something else to light my case up :p
Cheers bud
Cheers bud
No problem mate
You double check your motherboard doesn't have both 3 pin and 4 pin
Headers?
Main thing with 3 pin is each led can be a different colour at the same time
Meaning can get fancier effects
No problem mate
Headers?
I will have to check the manual in a sec but going by the website its only 4 pin
That's a shame
There are some 12v neon strings if the
Bending around angles was what
You needed
Though ebay or Ali would be where to find those
If it's just to spread light standard led strips are better
That's a shame
You needed
Just checked, definitely both 4 pin 12v headers :( i may get the single colour strips that are 12v just got to work out what colour
Fair play to them, I think they've been great through this tough time
Yes they have
Fair enough their main competitor got
Next day delivery back on track a while ago
But they're a bigger company
And I returned something to ocuk and to
The competitor same day
My ocuk one was refunded yesterday was only collected Wednesday
But nothing from the competitor so far
So it's not just about will you get it
The day after you order
There's other considerations of what is good service too
