Man of Honour
- 21 Nov 2004
Damn wish I had of seen this earlier just fitted my kit to my nv7 and they don't work. Gonna have to apply for the updated controller now.Hi guys, anyone had any issues with the NV7 LED controller and the NV7 LED kit?
There seems to be a need to visually document the issue prior to an RMA issue.
I have the case from OCUK and the LED kit on order and was wondering if OCUK has a stance on the controller? I'd be happy to pay cost for it and swap it out AHEAD of having to 'prove' to avoid having to tear out elements of a 'finished' build to sort out a RMA'd controller?
I have just taken delivery of the LED kit and the bottom half would not light up dodgy controller, ended up using a splitter cable for now so they are on different channels and that did the trick am on to phanteks support about the issue but really don't want to be pulling apart my rig so may just leave it as it is at least it works now.Damn wish I had of seen this earlier just fitted my kit to my nv7 and they don't work. Gonna have to apply for the updated controller now.
Been waiting over a month for a replacement controller. Waited 5 months for the led kit. Bit of a joke really. I found the support to be really rude as well.I have just taken delivery of the LED kit and the bottom half would not light up dodgy controller, ended up using a splitter cable for now so they are on different channels and that did the trick am on to phanteks support about the issue but really don't want to be pulling apart my rig so may just leave it as it is at least it works now.
Side intake with reverse fans. Bottom intake with reverse. AIO on top with regular fans.
That setup is for if you have a radiator on the side panel, if you've only got a AIO going in the top, you want the airflow setup which has fans as intake on the side panel.
Is that the Arctic Freezer III 420? That’s what I’ve got but going to ditch the included fans for D30s.
For any fish tank case, unless running one position at much higher rpm than the others, I always used side and bottom as intake and top and rear as exhaust. Bottom will feed cool air for the GPU, side will feed the top AIO. Back intake is possible too, but usually is the only spot without a filter.I thought just the one intake was strange, so you would recommend 2 intakes?
You need to change the led count in the rgb software from 150 to 250 then it works, found this out on my build with asus motherboard.Been waiting over a month for a replacement controller. Waited 5 months for the led kit. Bit of a joke really. I found the support to be really rude as well.
I just love to bathe in lots and lots of rgb every day
