OcUK Staff
- 26 Nov 2014
- Stoke
Available for preorder today, we have the new Phanteks P300 Air & the eagerly awaited Evolv Sound DRGB Mini Speakers. The P300 Air expands on the success of the P400 Air that was released last year, offering the same idea on the P300 range of chassis. The entire front panel is comprised of Phanteks high performance mesh, which allows for much better airflow whilst reducing dust intake. The chassis itself is based on the existing P300 design, with the extra option to add a vertical GPU mount using the mounting kit (supplied separately) Otherwise you get all the features present in the original P300, including a tempered glass side panel, 355mm GPU support, 280mm front radiator support, a rear 12cm performance fan, 165mm CPU cooler support and more. Stock is due next Monday!
We also have for preorder the Evolv Sound DRGB Mini Speakers. Originally an elaborate April Fools joke, the Evolv Mini Speakers have been made reality due to customer demand. The Evolv Sound DRGB Mini Speakers are a faithful rendition of their bigger Evolv X series cases, with the same distinctive front panel shape, along with a 10W peak output & digitally addressable RGB lighting. They have integrated buttons for controlling the sound & lighting, and can be connected by 3.5" mm along with a USB Type-C connector for power.
Frankly I have no need for a pair, but as an Evolv X owner, I'm going to have to get some! We have a limited amount of stock arriving before the end of the month, this won't be a long term product as far as I'm aware so jump on it if you want some!
Phanteks Eclipse P300 Air Midi Tower Case - Black Window @ £49.99 inc VAT
Premium Midi-Tower from PHANTEKS in black, Mesh front panel, Tempered glass side window, Pre-installed 120 mm fan, Power supply shroud, Integrated dust filter, 2x USB 3.0
Only £49.99 inc VAT.
ORDER NOW
Phanteks Evolv Sound DRGB Mini Speakers - Black @ £26.99 inc VAT
Compact loudspeakers from PHANTEKS, Stylish aesthetics, Compatible with Evolv X case, Integrated ARGB-LED lighting, 6 Watt RMS
Only £26.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
