1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Phanteks P300 rgb/led
Discussion in 'Case Central' started by ScBHavoK, Feb 13, 2018.
  1. ScBHavoK
    Gangster
    Not long got this case and not sure what would be best to put in for a bit of light, either a coloured fan or an rgb led strip? don't want anything that will give me a seizure!
    It's an older system inside at the minute (am3) mobo so from what i can see wont have a header on the board to plug something in direct
    The case has a lit power button and rgb button to change colours and a faint led stripe along bottom of vision panel
  2. TheVoice
    Capodecina
    Phanteks RGB LED strip, they come individually in different lengths or the start kit which includes two shorter strips with an extension cable and some other bits, and it'll be controlled by the button on my case. I got a 400mm one for my new Enthoo Evolv mATX to provide a nice highlight and it works really well.
  3. ScBHavoK
    Gangster
    Thanks where would this connect up to?
    I think there was only one connection coming from the rgb colour change button and this connects to existing led strip?
  4. TheVoice
    Capodecina
    There may be more than one connector, mine had two.
