Hi.
Im sure ive built in this case before and getting some dejavu that im going to need some extra cables.
The case has 3 ARGB fans in front which is fine. My motherboard is MSI Tomahawk MAX and gpu Gigabyte 5700 XT.
Can this be directly connected to sync up the mobo software with the case and fans?
I also want to see about adding in an extra ARGB fan to the rear and led strips.
Does it all have to be Phanteks own brand?
This is the adapter I seen and started thinking I needed this before:
https://www.overclockers.co.uk/phanteks-rgb-led-adapter-cable-ca-057-pt.html
Cheers
Cheers
I've learned a little bit about the crazy world of RGB in that time.
