- 8 Jan 2019
- MSI HQ
Hi everyone!
The Metal Mesh front panels are available to pre-order! Whether you need a replacement for your P400A case or you want to breathe some new life into your older P400 or P400S cases, the Metal Mesh front panel for the P400 Series is just what you need!
Please note: The P400 and P400S whilst compatible, the fans will not look fully centered, infact they will be about 8mm off center. See images on the product listing for comparison.
Phanteks Eclipse P400A Metal Mesh Front-Panel - Black @ £17.99 inc VAT
Replacement front cover for the PHANTEKS Eclipse P400A, Equipped with a fine mesh for optimised airflow, Also serves as a dust filter, Compatible with the Eclipse P400 and P400S (Not 100% Exact Fit!)
Only £17.99 inc VAT.
ORDER NOW
Phanteks Eclipse P400A Metal Mesh Front-Panel - White @ £17.99 inc VAT
ORDER NOW
ORDER NOW
ORDER NOW
