Panel arrived today, works a treat lowered my GPU temps by 7C over the stock panel with the filters removed!
so basically not worth bothering then...
Thank Your Sir. Hopefully, this will improve temps even more - why isn't this stated on the product pageJust a heads up for anyone swapping panels, the P400A panel is lacking the top and bottom vents of the P400/S panel and also doesn't have the LED diffuser, e.g:
Good news is these parts are all interchangeable and it's a case of 8 screws and swapping them over for a bit extra airflow and getting the downglow back.![]()
Any news on if the black variant will be sold again? Cant believe only 1 retailers is stocking this in the UK.
I got my front mesh, and boy it improves my 7700k and RTX 2080 by a big margin.
Thank you Overclockers UK for supplying them.
They will be back in stock Mid January. What limited stock we had went pretty quickly.
Check the links in the opening post, they're in stock at OCUKHi.
Do you know when those meshed panels will be available?
Where can I get one. I need it urgently.
Opening post still states 8cm off centre rather than 8mmCheck the links in the opening post, they're in stock at OCUK![]()
will using the 400s cause the airflow to by-pass the mesh filter on the 400A?Just a heads up for anyone swapping panels, the P400A panel is lacking the top and bottom vents of the P400/S panel and also doesn't have the LED diffuser, e.g:
Opening post still states 8cm off centre rather than 8mm![]()
