RoFL
Tealc, you getting back into PWM converters? If you are, I could loan you one of my hubs to play with.
Fair enough, but explain how when a 4 pin fan was plugged into header one on the hub, and the hub was plugged into the CPU OPT header it worked for all fans, apart from the issue of the 4 pin not always spinning up.
So it worked most of the time with a 4 pin fan plugged into the hub but not with a 3 pin plugged into the hub.
