Phanteks Revolt X issue
Having this same issue, did anyone manage to find a fix for it? I have an inkling that it may be something to do with the sata connections, but haven't been able to test it as of yet. Any help would be appreciated
I have the exact same issue that I'm waiting for a reply on. It'd be nice to hear if someone had a good outcome or what was done to resolve
Having a small problem with my Revolt X 1200. When the ITX system is running, and I press the ATX system power button, the PSU terminates power completely. This only occurs in this order, not in reverse where the ATX system is running and I power up the ITX system. It also does not happen every time.
The system is totally dead and power cannot be restored for a short period of time, but it isn't a fuse as later it all powers up fine.
I am using the dual system capabilities, but with the 1200W PSU, don't think the specification is anywhere close to pushing the power limits:
ATX spec:
AMD 5800X
MSI X570 Tomahawk
32GB RAM
Gigabyte 3080 (2x 8pin model)
2x m.2 & 2x SATA SSDs
Full loop with D5 & 14 PWM fans off an Aquaero 6
ITX spec:
AMD 4750G
Asrock B450 ITX
32GB RAM
1x SATA SSD
I haven't been using the main ATX system as much as I would like but haven't encountered any stability issues so far (touch wood). Reluctant to take apart for proper troubleshooting given time and the loop so wondering if anyone has any thoughts/suggestions?
Cheers
Ian
How'd you get on with this?
Nothing useful from Phanteks thankfully, clearly gone down significantly in customer service and product quality, I won't be touching them in the future for anything other than a case at a push.
I did switch the motherboard as I was having some other issues, still the same with a gigabyte B550. I haven't had chance to strip it down and test thoroughly but may do so soon given my loop is due a flush.
Rather than create another thread, do you think the 1000w revolt X is suitable for powering the following?
System 1 - 5900x, B450 mobo, 32gb ram and 3070fe.
System 2 - 5600g, b550 mobo, 16gb ram, elgato capture card.
All of this combined with 7 case fans, a 360 AIO and around 6 usb devices.
