Phantom or 600T White?
9 Jan 2012
I like both these cases and can't decide one to get. Not sure whether to go with better build quality and cable management (600T) or the cool look and superior airflow (Phantom).
Any thoughts?
600T so you can occasionally look through the windows and just drool, especially if you're getting watercooling etc :D
i use the standard fans with a extra exhaust in the back and to be fair they do a decent job but eventually ill change them out as they are far too loud at high speed.
Whats better 2 120mm's in the top or a 200mm?
A 200mm should move more air, but moving more air causes noise from teh turbalance in my experience since the fans themselves arent really noisey its the air moving through them but im sure some really good low rpm fans would remove most those issues. personally when I switch them out ill be putting 2 x 120's in front and 2 up top but thats just my personal preference.
So there's 2 120mm mounts on the front too?
no there isnt but there is a mesh there that looks like it will easily take the screws and fit 2 x fans ill check it out tommorow for you when i dismantle my rig for some new parts.
Cheers, so I'm thinking if I get the 600T I would put 2 120's in the top, a 200 (maybe 2 120's) in the front and a 120 in the back. I would probably get all new fans. Good idea?
How are the corsair fans as the NZXT included ones are meant to be quite good actaully?
Loud at full speed and i dont think they shift enough air, also you have the option of putting the mesh side panel in which is included that allows you to mount up to 4 more fans on the side of the case.
Mine are not too bad, but if you get the phantom, you have to buy nzxt fans as they are made to fit iirc right?
Surely that's only for the 200mm's? Which I was planning on doing anyway.
I was thinking about the fans as I dont want to spend excessive amounts replacing every fan in the case.
Completely undecided over these two cases. I'm sort of an airflow freak and the phantom appeals to me more for that and I think it looks nicer.
The 600T has really nice build qaulity and a tonne of cable management.
Hmmmmmmm
id rate the air flow as average at best with the standard fans but it has huge scope for improvement on the 600t you could go nuts on the amount of fans you could have in it tbh.
Ok so say I got the white 600T and wanted to use the windowed side panel. I would put a blue 200mm in the front as an intake, move the HDD cages, put 2 120mm blue's in the top and a 120mm in the back all as an exaust? Yes I know I'm a bit of a blue led fanboy.
