Hello!
I just bought this https://www.overclockers.co.uk/showproduct.php?prodid=HS-038-ZA and some MX-2 TP.
I bought them because my Phenom II 940 was running at 50-60 idle at 3GHz,
Now I have applied the MX-2 paste and installed the Zalman but even now, with the fan at max (2400rpm) I'm still getting a reported 60c idle and 70c under load :|
Could the CPU be reporting the temperature wrong? Or could it be faulty?
I'm pretty certain I fitted everything perfectly, and the Zalman is unbeleivably secure in place!
Also not much air flow in my case, but my 4400+ X2 ran never more than 40c :s
Thanks
Thanks
