Of course I had to get my X3 720be up to 3ghz which wasn't a problem Only thing is I notice CPU throttling no longer works. CPUz shows it stuck at 3013 all the time whereas on auto it throttled back to 800mhz when not working hard. I have a Gigabytle Ga-MA770T-UD3P.
Might put it back to auto as it doesn't need to be running full 3ghz all the time.
Now the cpu seems to stick at 3ghz all the time. I'll check it's on in BIOS. Cool n' Quiet is set at Auto by default. Should I set it to "on"? Also does C & Q work with win 7's own power management or do I need the AMD software?
