Phenom II Overclocking Help Please :D
4 Dec 2009
Worcestershire
I have managed to hit 3.4ghz on stock voltage with my Phenom II 955BE by increasing the multiplier. I am now trying to hit 3.6GHz but can't seem to do it. I have tried raising the CPU voltage to almost 1.5v and I have tried increasing the CPU-NB freq to 2.4ghz but it still won't post and I have to clear my cmos. Any suggestions? Thanks
My board is a GA-790XTA-UD4
You dont wanna go over 1.5v, so you done right there. You are increasing the FSB now right not just the multiplier. Also what temps were you getting at 3.4ghz?
Hi Guitarman0, I suggest you head on over to this thread (if you haven't already) and post up your results and problem there as it's checked much more regularly by people who will be able to give you very specific tips! Best of luck.
Looks like your Venomous X is working well for you, good stuff!
got my x4 955 @ 3.6 using normal volts with gigabyte board just by using multi
had cpu/nb @2.6 on 1.3v
back on 2.4 @1.25
corsair ram ddr3 1.65
passes prime fine must have a good chip :)
