Can anyone clarify what settings I need to run it as a triple core? Should ACC be set to Auto or do I need to change it to All Cores or Per Core for trying it as a tricore?
I got my one unlocked to 3 cores using:
ACC per core
Unleashing mode on
and then trying the 0,1,2 or 0,1,3 options,
For me 0,1,2 was the one that worked.
Also try fiddling with the settings under acc per core. I think they are all set to -2 by default? Try setting them to +2 or just generally trying different things. I am not sure exactly what they are but it is to do with the amount of headroom the chip has to overclock. I think positive numbers are for cores with less headroom... Not sure though.
Also does anyone know if the unlock disables the chips automatic temperature cut off as well as the monitoring sensors?
