Philips Hue Lights Advice
7 Nov 2006
Stockton on Tees
Hi Guys,
Looking at getting the starter kit for my lounge and have a few questions.
- At the moment I have a standard (non-led) dimmer switch which I use to dim my halogen bulbs (2 on 1 circuit). Will the Hue still work on this dimmer switch or do I need to change it to LED dimmer switch?
- I also have a floor lamp which is connected to a dimmer switch via a 5A 1-Gang Round Pin Unswitched Plug. If I changed the blub from halogen to Hue will it still work?
- Can they come on using motion?
- Can they start coming on when it gets dark gradually increasing to full load?
- will they match the lumen out put of a 75/100W halogen?
Thanks
