Phone with strong antenna?
19 Oct 2002
Woolyback Country
Looking for a phone with a strong antenna,something better than my old Samsung A70
Signal at home is not very good downstairs.not much better outside for that matter
Not looking at more than £200 tops,is there anything in that sort of range?
Refurb is ok too
There's only so much antennas/modem can do. What network are you with? Do they support WiFi calling? My home has poor coverage from all major networks, but WiFi calling has pretty much covered it for me.
Giffgaff an O2 reseller
The family all have Giffgaff so we get free calls to each other
I did a bit of research and a few of the high end phones are said to be better reception in fringe areas like me at home,out of my pocket though
My phone\network don't show WiFi calling as an option sadly:(
I have a Xiaomi Redmi Note 14 Pro on Three Network, with WiFi calling option switched on in Settings (shows Vo WiFi next to signal strength icon).
Xiaomi phones are quite cheap but fairly decent. The WiFi calling will depend if your network offers it, but I would imagine they all do.
SamsungGalaxy A04s, A05s, A13, A14, A15, A23, A24, A25, A33, A34, A35, A52, A53, A54, A55 and later
`if my phone is the A70 it `seems` it should work:confused:
Yes but no.
The A70 is from 2019 (whereas e.g. an A55 is actually from 2024), and depending on software updates may not have ever got the capability.
gotcha i `assumed` that the `and later`indicated that it should work
will look at phones on the list later today :)
Just bare in mind that list is not fully complete, it's most likely limited only to the ones giffgaff had time to test themselves. Probably best to search "[phone you're interested in] giffgaff wifi calling" to see if there's anyone who's using that combo before purchasing.
Apparently the A70 can do WiFi calling, at least according to Vodafone AU, but maybe not for the UK variant or not compatible with giffgaff/O2's network.
phone arrived today......
and is showing wifi calling :D
less ram than my old a70 but i cannot see any difference
seems to be a better signal too,even gets a `weak` 5G signal upstairs by a window lol
still setting up atm
update
been using this for about 2 weeks now,wifi calling works fine,long enough battery life for me
finding it quite a bit `laggy` compared to my old phone though :(
still did not want to spend a lot....cheep skate me :D
