Has anyone used Photomatix Pro 4.1 and what are your thoughts on it?
I disagree with that.Cameras have wide enough dynamic range nowadays that you don't need HDR as long as you can expose properly,
As wide a range as they may have, I'm pretty sure you still get more range from a HDR image? I could be wrong... But it seems unlikely! It's just another tool to use and it's up to you how you use it.
As for the OP - between Lightroom and Photoshop I haven't really felt the need to try anything else so farNot the cheapest combo but definitely worth a try.
Any modern sensor will be able to capture about 12 stops of range without any real issues. As far as I know, most prints won't hold that sort of range and nor will any screens. Unless you're exposing horribly there shouldn't be any need for HDR unless you are actually manipulating the light across the frame to bring back detail that the print wouldn't naturally support.
