PHP array problem
25 Jul 2005
Hi,
I'm trying to display an unset number of images on a page, using an array to hold things like the directory and filenames etc. However, instead of echoing the values of each image, the single letter in the $key position is being echoed.
For example "uploads" 2 gives the letter L.
I've had this working on a separate page, but the code looks exactly the same. Can anyone point me in the right direction? Thanks.
Code:
$directories = array();
$filenames = array();
$locations = array();
if($imageConn->num_rows()>0){
while($imageConn->moveNext()) {
$directories[] = $imageConn->getField("directory");
$filenames[] = $imageConn->getField("filename");
$locations[] = $imageConn->getField("location");
foreach ($directories as $key => $directory) {
  echo $directory[$key]."<br />";
  echo $filename[$key]."<br />";
  echo $location[$key]."<br />";
The following code
Code:
echo '<pre>';
	print_r($directories);
echo '</pre>';
gives this...
Code:
Array
    [0] => uploads/
    [1] => uploads/
For the benefit of others, you were telling it to put each element of the array into $directory, then telling it to output the letters of that entry that correspond to $key, rather than just outputing the whole of $directory.
What you probably wanted was
PHP:
<?php
$c = count($directories); // Do the count before the loop to save it having to recount the array on every itteration.
for($i = 0; $i < $c; $i ++)
    echo $directories[$i];
    echo $filenames[$i];
    echo $locations[$i];
This is assuming that the 3 arrays will always be of the same size.
