PHP Sessions Help
Permabanned
13 Nov 2006
Hi guys. I'm basically storing a few simple variables on my site with sessions. Is there anything else apart from session_start() and actually storing the vaiables that I need to know about.
I assume a unique id gets generated for every visitor automatically?
session_start() looks to see if the user already has a session through a cookie or URL. If not it generates an ID and sets a cookie (if possible/allowed) otherwise appends the session ID to each link in the page.
You can get/set the session ID with session_id if you need it to be portable across domains or similar.
Use the $_SESSION array to store variables.
HTH :).
session_start(); // Use that on every page that involves a session being used..
$_SESSION['variablename'] = ''; // Use that to define a variable in a session
Then I would use..
if(isset($_SESSION['variablename'])) {
if($_SESSION['variablename'] != "") {
header('Location: login.php');
} else {
echo "Session is blank";
header('Location: login.php'); // Redirect to a different page
ooo the fun I had last night with isset and empty!
Whatever you do in PHP make sure you use them 2 in the right places otherwise it causes murder! I was having things set but set as empty, and I had an if statement that checked isset instead of empty :@ so it returned true everytime!
