PhysX FluidMark 1.5.2
Good stuff chaps :)
A few more entries and I will start splitting them up into categories :)
I think there is a small advantage to using 2 GPUs as the program does the rendering on one and any other tasks on the other. A third or forth GPU makes no difference at all, they are totally idle.
You could have Single GPUs and Multi GPUs (2,3 or 4).
Use driver 320.00 and you will get a massive boost, you can also overclock very high on this with a Titan, check the clocks on mine on air.:)
Been playing around with KGB and nvflash today as well as updating the drivers to the newest Beta ones.
Because this is only a short benchmark I was able to push the GTX 660 pretty hard. Can almost get it to finish at 1280mhz core but this is all it's got to give, for now.
Yer, I will be separating Multi GPU's as well. Just need a few more entries to go for it :)
