Pico power connecter
30 Dec 2005
Hi guys
I have a Pico 160W PSU. At the moment it is connected to my N54L Microserver but the DC 5.5mm socket is just hanging out the back through the top of the expansion over that flips over.
This is meant to be installed in the case but I am assuming I can just drill a hole in the case and using the nut on the end to just secure it?
Should have asked this 10 years ago! lol
Thanks
Don't the motherboards for SFF ITX boards usually have a pop-out in the I/O shield?
Edit: oh, it doesn't even have an I/O shield, nevermind :o
Yep should be fine to do that - or if you don't fancy drilling the case, PCI blanking plates are an option that can be drilled
Thanks guys, dont have space for another plate as there is only 2 slots, 1 has a graphics card in it and i've just added a 2.5Gb network card.
