Piercing Q's (FAO Blackstar/Penksi really... :) )
4 Jul 2004
aberdeen
Given up finding my other thread on it, and anyway that was more about tshirts ... So ...
Decided to go with an eyebrow piercing, cos (i hope ;) ) it'll make me look older than a lip/tounge one, and its more ... i'm not sure how to word it, but looks more "smart" if you get what i mean (imo, anyway).
How much should I expect to pay for an eyebrow piercing?
Also thinking of getting some form of ear piercing, anyone got any links to a site that shows each type of peircing so I can just ask for it without having to explain (not after just a simple hole in ** eyelobe, want one at the top part of ear, if i get one). Also approx how much would this be?
And just to be a bit nosey, how much for a lip piercing, approx? If it is really cheap I might just get it for the sake of it to see if it suits me :p. But IIRC they're like £20-30 so bit too much to spend just to see if i like it.
I know some of you will moan and say how you shouldn't care, but what side (left/right) is considered the gay side to get a piercing? (ill get the non gay side, obviously!). It is just I dont care what side, so no point in making me look gay.
Cheers
Cheers
Why is this obvious?
Oh and its the right for teh gay btw
MB
Could be anything from £15+ for any of those piercings... depends where you go of course.
And about the lip placement. Have it done in the middle and you have no worried about having it on the "gay side" :p
Might get my lip done soon.
Prince albert
So if I get left, I won't look gay, yeh :)
And what are you on about with the obvious thing? :confused:
And ren, i wouldn't get it on the side anyway. I'm not going for the emo look ;)
Hedonism, where i've been for my piercings here in Stoke, charges about £20 for eyebrow piercing although a mate of mine did it himself with some form of needle and it did actually look quite good.
I have my left ear done at the top, cost £3.50 at the local hair dressers.
You said
I'll get the non gay side obviously
and I wanted to know why it was obvious?
MB
It won't make you look older...
Price it depends where you go. I'd worry more about the quality of the studio than the price to be honest. I think an eyebrow in the studio I frequent is about the £20 mark, with a lip being about £25. (Might be £20 as well)
As for a diagram, Paula's got one somewhere on her site.. I shall try and find it :)
Edit: I can't find it!
As far as knowing what they're called goes, just point!
Because I'm not gay. And if i don't even care what side I get it on (tbh, either side is fine by me), no point in getting that side :)
Matblack said:
You said and I wanted to know why it was obvious?
MB
No such thing as a gay side. Anyone who says there is is just secretly gay and trying to divert attention.
Sorry I'm not trying to be facitious but theres no reason to conclude from what you said that you aren't gay and that it should be obvious you would want it on the 'non gay' side :/
Oh well [wanders off]
MB
hey mohinder, its because you have "swallows" on your back, thats gay.
;) lol... you said it yourself :) ..not me!!
Mohinder what where you looking for a diagram of?
Eyebrow piercings about about £20-25 depends on where you go. Anyone who tells you that having a certain piercing is gay is just really dumb.
Anyway any gay piercing i have is canclled out by a different one.
Mohinder would you like that little taper back i'm 4mm in each ear now (ps got the next size up?)
Edit: twas this picture
