PING Annoyance
Man of Honour
21 Feb 2006
I am at a loss and frankly it is boiling my ****!
A speed test on my internet connection which is consistent and more than healthy enough to game with.
A server list (it's bad today) but 27 PING rates more than good enough to game
So if I select say a 27 PING server why does this happen EVERY TIME I enter ANY game??
BF1/BF4 ALL the same
I have a mega PC more than up to the game
I am connected to the router via a cable which is 1 meter long and has been replaced MANY times
I have checked that nothing else is running (Netflix/Prime/Apple TV etc) when I seek to game
This happens without fail within 5 minutes of trying to play any of these games online, any time of day. I am at a loss how to fix this and it seems so is the entire internets.
Help me Obi Clocks you are my only hopes :(
Check what MTU you are using versus what the ISP supports - if its way out it can cause issues with gaming and lag.
EDIT: Just in case it might be worth getting these stats - some people have things like auto receive window tuning settings that can seriously screw up gaming:
Open commandprompt as admin and enter this: netsh interface tcp set heuristics disabled
Hit enter.
After doing that, enter this: netsh interface tcp show global
Copy the output from that command on this topic so I can see it.
Receive Window Auto-Tuning Level being one of the more interesting ones to check.
Also might be worth trying with Windows firewall disabled :s to rule out something like that and likewise any 3rd party firewall or AV (though if you are directly connected without NAT or something sitting in between that isn't a great idea).
TCP Global Parameters
Receive-Side Scaling State : enabled
Chimney Offload State : disabled
Receive Window Auto-Tuning Level : normal
Add-On Congestion Control Provider : default
ECN Capability : disabled
RFC 1323 Timestamps : disabled
Initial RTO : 3000
Receive Segment Coalescing State : enabled
Non Sack Rtt Resiliency : disabled
Max SYN Retransmissions : 2
Fast Open : enabled
Fast Open Fallback : enabled
Pacing Profile : off
Initial RTO : 3000
Fast Open : enabled
Doesn't look like anything amiss there.
Are you using the Network interface onboard your motherboard?
A cheap 'test' would be to get a PCI-E network adapter and bung it in your PC, and see if you get the same problem or not.
Whatever it is, it's obviously system-wide.
My motherboard has both wired and wireless being an ASUS ROG Extreme V. I have latest BIOS enabled and normal network traffic is fine, zero issues and no issues with anything internet bar these games.
I have never really been a pc user who suffers issues. For decades my stuff just works, games never seemed to crash, never had network issues, it has been a pianless experience as I keep a clean PC and keep it updated with good bits. This is my first ever 'one of those issues' really that I see everyone else have :(
No issues with Counter Strike it would seem
Wondering if some kind of firewall settings or similar are causing problems with BF4, etc. they can use some odd connections and/or traffic cycling that can trip DOS protection on a router, etc.
I turned off Firewall, issues still there :(
I tell you, it's an odd one this, hence the post
I have seen the same old same old over and over
- Drivers
- Firewalls
- Virus
- Malware
- ISP
- Fault this and that
- You're doing it wrong
- Router
etc etc etc
But all of that I have checked, first ports of call but this one is odd :(
Appreciate everyone taking the time mind
I had a similar issue years ago; would get massive packet loss & high ping only in Cod4 - turns out one of Plusnets gateway providers had incorrectly mis-prioritised traffic for the ports which most Cod4 servers used :mad:
I've seen a fair number of people complaining about high ping on the BF subreddit over the last few weeks - have you tried connecting to a US server out of interest? Even though the baseline ping will be higher, it might narrow things down a bit.
