Pirelli Angel ST or GT?
2 May 2004
I need to get some tyres for winter and have decided on the Pirelli Angels (can't really be trusting my Supercorsas in mid winter!).
Does anyone know the difference between the GT and ST tyres? Some say the GT is designed for heavier bikes / pillion riding etc. but others say the GT is just the longer lasting better tyre?
Any ideas?
Thanks
Any ideas?
Thanks
The GT's replaced the ST.
I've got 3000 miles on my rear GT already and it's not even started to wear, mind you that is on a 50bhp 400cc bike, a 130bhp bike might wear it out a little faster.
I've not used them much in the wet, but in the biblical rain we had friday I completely forgot about them, which can only be a good thing. With my old front tyre I was always 'aware' of it not giving the best grip, these were lovely.
Ah, that clears that up, thank you :)
My Supercorsas have done 3k so far and are still pretty good. A tiny bit squared off from a long run on the motorway, but nothing too bad. Hopefully the Angels will do even better.
Sensibly I'll keep the Supercorsas for next year if they're still good by the time I replace for winter. Not sure how I feel about sticking old, partially squared off tyres back on, but then I'm also not sure how I feel about getting rid of perfectly good tyres :p
Yeah they're basically an update, better cold/wet weather grip and durability. I think they make a version for big heavy bikes, the standard GT is just for normal bikes.
I'll get a pic of my rear tyre for you, it is going slightly square, but only very slightly, I do 200 miles a week commuting on 95% straight roads so it's going to happen regardless.
either will do imo,i have the gt on the front and just replaced my worn out rear st with another st as it was slightly cheaper
I cant tell any difference between the two regarding grip
they hold the world endurance tyre record so you'll get a lot of mileage out of them
Cheers. Would be good to see how they wear & also what they look like once they've done a few miles :)
IMG_20150727_183050743 by Paul Sims, on Flickr
IMG_20150727_182928506 by Paul Sims, on Flickr
You can see the profile is just starting to square a little (bad phone camera pic), but in the first pic you can see the harder compound band in the centre a little clearer.
IMG_20150727_182953010~2 by Paul Sims, on Flickr
And this was at a couple of hundred miles old.
IMG_20150525_160702644 by Paul Sims, on Flickr
I'd say, at very worst, they're a third of their way worn in the very central band, which would mean they'll last 9000 miles. I reckon I'll easily get 10k+ out of the rear without issues based on their current wear rate.
This tyre has done 800 miles to Wales and back, 320 miles of which was motorway. Then 1800 miles of commuting (straight roads, 2 decent corners on my whole commute!), and lastly 500 miles of Sunday riding (corners!). So that's roughly 2000 miles of straight line roads, and 1000 miles of twisties.
Nice, thanks :). They look good, nice & meaty! Would like quite nice on the Speed I think. They look like they scrub in nicely.
Where do you live?
Its supposedly summer here in the UK ;)
Hah yeah, supposedly. It is almost August though, and I can feel the weather getting colder already, plus I hate rushing stuff, so would rather have the tyres in the garage ready, then I can book fitting in advance and also need to order the front lift bar thingies for my abba stand so I can get both wheels of at the same time.
Yeah they're very good tyres. Pretty damn good in the twisties too, this was on the 2nd day of my Wales trip, zero chicken strips.
IMG_20150619_105526262_HDR by Paul Sims, on Flickr
Have you thought about picking up a 2nd set of wheels, chucking the supercorsas on one set and the GT's on another? Doesn't take long to change over wheels.
Oh and bear in mind that rear tyre is a 160/60 so pretty narrow compared to the 180/190 or the Speed.
That did cross my mind actually but kind of disregarded it as I thought it'd be really expensive. I will have a look into that though cos then as you say, it's a few min job to change over. Would actually work really well considering the disk and sprocket aren't on the wheel, so it just slides off.
Be a bit more of a pain for the front though.
It's a shame the 2015 R model doesn't come with the forged wheels, you could have bought a set of non R wheels, then had the supercorsas on the forged set and the GTs on the normal wheels.
Stick a bag of sand on the back or get someone to push down on the back end, much cheaper :D
GT is imho the best all round road tyre available. I'm on third set, big miles, epic on track... Stunning in the wet. I'll never change tyre.
Got mine on at last. Taken them out for 2 blasts today, they're so good in the corners!
Well worth it. Feel really nice and manoeuvrable at slow speeds as well, but that's probably more cos my old original tyres were starting to square off :p
They're more scrubbed in now. Pic above had never been ridden :)
I really fancy a set of GTs but can't justify the £250 when there's still plenty of life left in my old tyres and they're not terrible.
