Plain cheap case for modding...
12 Nov 2008
I wanted the YCC-61F1 Globalwin case to start modding. But i cant find anywhere that sells them.
So does anyone know a very cheap case (£15 or so) that has a cable management system, that would be good for painting/adding a window and general modding?
Ive seen a few but none have any cable management, i wanna be able to hide the cables behind the motherboard tray like newer cases :)
Your best bet would be second hand I think. Not much worth getting new for that price. With enough posts, you may be able to find something on the members market here, or an online auction site perhaps.
Cut some holes in the motherboard tray yourself, then you can hide the cables between the tray and the other side panel.
Antec 300 is nice and simple, but about £35 iirc.
