plaster bonding
22 Oct 2004
Berkland
Hi guys, I'm looking to repair a hole where drilling the wall to attach a curtain bracket went wrong. Basically the area to repair is about 10cm diameter max, and probably about 1cm depth for most of it apart from the drilled hole itself.
I have tried repairing it before and it did hold the bracket, but around the edges the filler started to raise from the existing original plaster just as I put the final turns in of the fixings/screws.
So, as I am sorting the room out before the new carpet goes down, I am going to repair it again. At the moment I have pulled all the loose new plaster out and its almost back to how it was when I first messed it up.
Any ideas on what sort of filler I should use to do a better job? Also is there anything I should do to get a better key to the existing plaster?
Cheers
right bodge incoming
knock as much loose out as possible, hoover out, pump the hole full of gripfill then push a rawlplug in where you need it, let set then a thin layer of filler over the top
+1 but I would tend to use epoxy resin - get a good two-part resin though. I have mounted slatted blinds with a 5mm deep hole and half a rawlplug due to the lintol above the window frame burning all my drill bits out and it it still there after 10 years :)
