Caporegime
- 21 Jun 2006
been getting a bit of an odd strain on my left leg after running, in between the shin and calf on the outside of the leg, so not really sure what is causing it.
so i decided i might as well start using the foam roller i bought a couple of years back in combination with foam roller app
https://play.google.com/store/apps/details?id=com.solidjade.foamrollerondemand
also downloaded stretch HD app
https://play.google.com/store/apps/details?id=com.sportsmedstudio.stretchhd
hopefully these will help sort this issue out, or are there better apps you guys use?
