@D.P. I know you tend to not surface in here often, but hope things are good with you and you managed to do that brutal 300km event you mentioned.
I read an interesting comment somewhere recently that suggested that instead of carrying a hydration bladder for long runs, to just carry multiple soft flasks in your rucksack instead. The theory being that it's easier to monitor fluid intake and also is a huge benefit when it comes to re-filling at aid stations as removing/filling/bleeding a 1L bladder can be quite awkward at the best of times and the hassle of hose alignment when taking the bag off, whereas this way you can just hand the volunteers around 5 soft flasks at a time, keep 2 up front and then the rest inside the main compartment.
What's your approach for your long runs when it comes to carrying fluid?
Yeah, mine is Decathlon too. Have you ever tried putting it in with the rucksack being full of stuff though like jackets/food etc? It makes it massively harder than when it's empty and that seems to be the issue. The initial fill isn't bad, but gets much harder when you add stuff to the other compartments. I guess in theory you could just try and squeeze the bladder out enough to re-fill, but then that might be awkward depending on the source of water at any aid station.
Nice one, I'm in a similar boat with Saturday mornings being the issue but I'm hoping to sort it as I want to make it a weekly event for myself. Speaking of which didn't parkrun used to be on a Sunday morning?
Thanks, might give them a try.
Been on a Saturday for as long as I’ve known it ~ 6 years.
They may as well have cocaine in!
They’re effectively a block of sugar, think Turkish Delight kind of texture. I had my first one and was suddenly running up hills without even thinking about things!
The overly sweet taste probably isn’t for everyone but the Coffee sample one I had was probably the pick of the bunch. Annoying given I didn’t buy any of those!
