There's a few people in running groups online who run for 100s of days in a row and some bigger distance (15k+) so it can be done. Although 5k is pretty low distance i'd be cautious about adding another day into the mix as the body does need time to recover. You could look at changing what you're doing on your running days so either making a run longer distance so you're working for longer or changing it so you're doing more fast work to get the HR up? 5k up hills will use more than 5k down hills
I'd still look at food though, usually can be cut back; i know mine can
i just accept that i'm not loosing weight at a high rate as i still eat the odd junk food but it makes me happy rather than just eating low calorie food all the time.
Went to a sports physio person last week, mixed thoughts on it really. You book an hour session but i was in there for 15-20 mins, he said my '
tibialis anterios?' so did some ultrasound on it and said my glute was tight so massaged that. I noticed on longer runs a bit of pain from my big toe to my ankle and sometimes to the bottom of my shin where it meets the ankle. He said he would send me some exercises to do and ended the session.
Mixed emotions in paying a chunk for a small period mind.
So 4 days later and no exercises sent over i decided to have a drive up to Pete Bland Sports in Kendal which is about 45 mins away normally (hour and a bit this time due to traffic) and wore my normal running stuff, i asked them about it and i got on the treadmill to check out what's going on when i run. Oddly my right foot (one with pain) overpronates when running and my left one is pretty much fine. He checked my stance normally and it seems i just overpronate on my right foot naturally. He said it can be caused by things such as injury or weak muscles but also explained it can be natural for the individual. I tried on a pair off Asics Culumlus 25 which he advised is a neutral shoe with a bit of support and the difference on the treadmill was clear as it pretty much made it perfect. They are quite expensive for some of their shoes and these were a tadge expensive so he had a look and he's found a few pairs of varying shoes they have in my size so is going to get them from the warehouse for next friday when i go back down. Think there some Saucony ones hes getting over, tempus and triumph maybe? He said doing short distances in what i have may not be to bad but as mileage increases the strain will cause issues. I also grabbed a head torch whilst there and tried on numerous running back packs.
Ultimate Direction pack was uncomfortable due to the bit you attach the chest straps to being really hard.
Inov8's pro 8 was mega comfy so they found the 2-1 which unfortunately was not, as the bottles diged in to my stomach, although i think it would be ok if i moved them to the high points.
I tried on the Montane Gecko 12+ and that was perfect for me, well apart from the price which was around £130, they said they have last years in the warehouse which is £65 and not to much different so they're getting that over from the warehouse for me when i'm down next Friday.
I did go out when i got back from Kendal, thought i'd give my nike Invincibles a run out instead of my asics noosa tri and toe and foot pain came around at 7 miles into an 8 mile run. Frustrating. I'm going to clean them up and chuck them on ebay as they've only done about 80 miles. Next time i go out i might try my Adios Pro 3 on a normal run, suspect they're stabler than the Invincibles as they have a good firm foam. If not i'll just keep the runs below 5 miles until i grab a pair of more supporting shoes. Bit of a pain as it limits my choice but i cannot risk injury over a fancy pair of shoes when ideally i need to be upping to around 50 mpw by feb next year.
