- 24 Oct 2006
Hi,
I've never used partitioning before but I have a new 160GB hd and will be be using my PC for recording my own music mainly but also for a few games and general usage.
Two questions as I've only ever had a drive C and downloaded all games and applications to it.
Firstly, with partitions, do you actually download applications to the OS partition, install them there and save whatever you create from the application on another drive... or do you install the application straight onto another partition (not the OS partition)?
Secondly, does this look okay for a setup?
1. XP (20GB)
2. General Usage (60GB)
3. Music recording/samples (60GB)
4. Backup space for most important files (20GB - also have external 250GB drive)
1. XP (20GB)
