As in constant cooling?
I'd assume they'd also give you the best chance of getting a decent overclock on air over a random chip.
There are other high end cooling setups that aren't as extreme as LN2 that can be used for more sustainable extreme cooling though have gone out of fashion a bit like phase change/peltier setups.
Can you use LN2 in an everyday system?
Much easier to get a "normal" phase change cooler and keep it at -50 C ish (compared to -210 C).
Keep an eye out for the ASUS ROG Neptune graphics card when it comes out.
those chips are suppose to do the advertise speed under water, not ln2. on the box of my 4770K it says [email protected] 4c4t, that is what it does under ln2.The reason I ask is because I looked at these:
https://www.overclockers.co.uk/productlist.php?groupid=595&catid=3079
The chips may do those speeds under LN2 but what is the point of buying one if you can't run it in an everyday system?
