please help idle temps high?
RJC
RJC
Don
29 May 2005
Kent
Check task manager and see what processes are using the cores.
Run prime to check full load temps, these are more important than idle.
OP
11 Mar 2012
portsmouth
the only thing i can see is IASTORDATAMGRSCV.EXE CPU AVG 22
can i disable this feature its the intel rapid storage i dont use it .i dont think.
29 Sep 2010
Must have something running, 50% use on 2 cores is not idle. :D
Restart and then have another go.
The mins at 33-34 degrees will be the idle temperature at a guess when nothing is running.
