I have the Intel Core i7-2600K 3.40GHz, the Asus Maximus IV Extreme Intel P67 mobo and the Cooler Master Haf X case.
I want to buy a good cpu cooler in order to overclock.
I am between the Corsair Hydro H80 and the Noctua NH-D14 Dual Radiator CPU Cooler.
Which one do you think will give the best results? I am also concerned about noise issues.
Thank you
Thank you
cheaper than NH-D14 and almost same performance.
