Please help me, home built computer will not work at all.
As much as I feel for this guy, I have been ****ing my pants reading this.
Do you have a power cable plugged into your gfx card?
That card doesn't need one. Its low power enough to draw everything it needs from the PCI-E connection.
To the OP: Unfortunately we can't see the 24 pin connection on that photo. Can you verify that it orientated correctly (hook thing on the right) and fully inserted (so you hear/feel a click as the hook engages)?
now, referring to the manual:
17) Phase LED
The number of lighted LEDs indicates the CPU Loading. The higher the cpu loading, the more the number of lighted LEDs. To enable the phase LED display function, please first enable Dynamic Energy saver2. Refer to chapter 4 for more details. thats all it says
HAVE YOU GOT IT CONNECTED TO A MONITOR YET?????? We need to know if all power imputs 4 and 24 pin are in place, and if you have messages coming up on screen.
best image i can get guys
nothing is showing on the moniter, just says power save mode, amber light etc. As far as i know the CPU is in place properly, followed the manual, notch lever thing is secure etc
looks okay.
So is it powering up, fans spinning, amber and red lights on board, then going off again??
Can you try a cmos reset (see manual)
IV ****ING DONE IT!!!!. im guna sound nooby, but i had the moniter connected to the motherboard thingy instead of the GFX card thingy, but its done and ima install now!. thankyou guys for all your help. I LOVE YOU ! <33333333333
hehheeh
So you installed a graphics card and didnt connect your monitor to it
Niceee
Enjoy your new pc matey :)
No mate you definately don't sound a "nooby" lol.. Good luck and for *UCK SAKE do what the windows disk tells you..
Hey I know someone who has built loads of PCs over the years and he did just that a few months ago.
