Please help me O/C e6600
Well i can get fsb to 360 cpu @3.240 but i can not get fsb to 400 keeps crashing.
I have cpu voltage at 1.45v "hope thats ok" northbridge at 1.50v and my memory is said to be rated at 2.3v which is what i have set it to, have tried 5 5 5 15 and 4 4 4 15
If its a case that my cpu can not go any higher then fine, I just want to know that i am not doing anything wrong ?
Also CPU-Z says its a B2 version and cpu temp shows 62o/c under load both cores.
How do you guys work all this :eek: thanks again
Got my new Freezer 7 pro cooler today "man it HUGE":eek: i did order some tim as well but thay forgot to pack it not like Overclockers:(
I will see if that can help me get to 400 fsb.
The tim that was on the new cooler "is that ok to use" ??
Yes the tim on the Freezer Pro is MX-2 and is supposed to be very good.
On a side note have you tried dropping the multi from 9 to 8 and trying 400 fsb
(3.2 Ghz)
yeah that TIM will be fine, i notice a diff in temps with that cooler from stock so see what you get with your current set up. As for reducing the multiplier it kinda defeats the object as hes trying to clock the cpu higher
well stock cooler was around 43o/c normal and 60-70o/c under load, now with new cooler it is 32o/c normal and around45-50o/c under load very happy and that is with cpu @3.240 do those temps look good to you ?
I will try again at going to 400fsb over the weekend.
