- 17 Sep 2012
- North-West
Extra questions for you, what network do you have at home? (G/N/N+)
GExtra questions for you, what network do you have at home? (G/N/N+)
Appreciate your timeThe pre-build:
Louder Drive
No Monitor
No Keyboard
Slower SSD
N wireless card when you only have G Network. (£30)
This spec:
Full System
Wireless Adaptor
Quieter OD
Quicker SSD
Keyboard and Monitor
Theoretically is it worth waiting until the January sales on overclockers or do they not really dip in price much?
Thanks.I keep editing the post because I've missed things aha
I am unsure how much the prices change during the sales
Oh. Confused now! Which rig would you pick then?
Do you have any ball park figure ideas? I can build it myself if there's a massive difference here.
Crikey. That's around the mark of me thinking it is now worth me putting in the time and effort myself.id be surprised if it was under £100 to build one, easy the price of that monitor
Apart from the £100!unless you enjoy building or you have something specific you really want in the pc, ie an enthusiast most likely you wont notice the difference
Yep done a bit of research plus work in IT so it'd be shameful if I don't know something! I just haven't ever built a machine before but I appreciate there's a sticky thread on the forum and videos aplenty so I'm not particularly phased - more being bothered - which at £100 I am!it looks like you know a little already as you custom with ssd and 7950, both nice adds
Well the steam sale has been kind to me - picked up Crysis collection, Fear 3, Rage and Max Payne 3. Plus there's something about having a quad core phone and a dual core desktop which doesn't quite cut it I don't thinkit depends what games you play tho, a speedy dual core with ssd and gfx might be just as fast and save a couple hundred
Thanks.
Are case fans required? Everything else looks to be there to me!
Confused - does your spec come with this?I'd advise one fan either on the front top or bottom as an intake, as big as possible.
£30 more I suppose for a Intel 330 Series 180GBwell there is that
if you are able to build yourself maybe you can afford put a bigger ssd in or something, would help a lot with steam
steam eats up space faster than anything, and honestly once you have a nice ssd a hdd, even a fast one doesnt cut it anymore, even more so than if its dual or quad, tho quad should last you longer
if it was my build id go big ssd even if i have to cut down on other stuff
i only use hdd for backup and movies things like that now, cant use one for games no more ><
Use the SSD for a boot drive and partial storage then a 500gb HD for everything else.
Yeah I thought this would be the best approach too - create a partition for the OS and programs and one for Steam.Use the SSD for a boot drive and partial storage then a 500gb HD for everything else.
Sorry David, I took the fans out but add a good 120mm and its still under £1000
Appreciate all your help - I may repost just before I pull the trigger to see if there's anything you'd change but I'm way more on track than I ever was.
IncognitoX - I've read elsewhere that the Titan computer has a better cooler, and it's got a better SSD. Couple this with a a guaranteed overclock and I'm starting to think this may be the better choice.The pre-build:
Louder Drive
No Monitor
No Keyboard
Slower SSD
This spec:
Full System
Wireless Adaptor (N but compatible with G, Good range, cheap) £12
Quieter samsung Optical Drive
Quicker SSD
After-Market CPU cooler (Performs better)
