Please help me to spec a new build
11 Aug 2015
Hi all,
I am looking for some building a new PC, monitor, keyboard, mouse with a budget between £900/1000 all in.
I think I prefer AMD, but things have changed a lot since I built my last comp. If Intel are now better that would work too.
I think 4070 would be best for what I’ll be doing (basic games CoD/Rust/etc), but again, more than happy to be led by you guys.
I believe I need it to be MicroATX so it first in the cupboard in my desk.
Thank you all in advance.
What sort of money would I be looking at for a 4070? Is Intel more bang for your buck than AMD?
For gaming AMD seem to the ones to go for, especially the 7800X3D that is destroying pretty much everything by Intel. I just got a 7700 so I'll keep that for a few years then drop in a newer gen AM5 CPU, upgrade ram- and possibly build up another AM5 rig with that 7700 and RAM.
Intel are better for things like video encoding as they have lots more cores.
Issue of Intel overvoltage is a concern also. Plus Intel change socket types more often, so you won't be able to get much newer generation CPU into a socket that's been out for years, AMD keep their socket for years.
For GPU's a bit more complicated but generally AMD give better VFM, have more VRAM, but Nvidia have ray tracing, lower power consumption (until yo go for 4090) better DLSS and frame insertion etc.
Not for my spec, no.
The 5600 non-X/X with a B550 motherboard is pretty much the same price and performs the same. You could flip a coin, or just look for a good deal for the whole package.
Realistically, it is going to push your budget into the £1100 region if you include the spec in my post.
OCUK did have some for just under £450, but they seem to have crept up to £480. I'd also be aware that the lower priced 4070 cards use GDDR6 instead of GDDR6X.
If you want to save the money, I'd say the 7800 XT is better value than the 4070 when it is priced near to or higher than £500. At £450, the non-Super is okay versus the 7800 XT.
Assuming a price higher than £500, then the Super is better value than the 4070, when the 4070 Super is priced at or below £550.
Okay so if I said the budget was £1,100 - what’s the best you could build including monitor (144hz 1440p), Ryzen cpu, 32gb ram, nvidia gpu, microatx case.
As expensive as GPU have gotten, it's nice to see HRR monitors getting cheaper and cheaper
But maybe that's how they sucker you into buying the expensive GPUs!
Yep, it's just compounding the problem :P a few years ago we were asking how long till 4k60 was viable, it's still not unless you're playing older games, but now people are looking for 4k240 or 8k :D
Hi all,
I would rethink putting your PC in a cupboard if you can help it, as you'll be choking the poor thing
Thank you all for your replies.
Yeah it’ll be housed in a cupboard, but the back of the unit will be cup off and the door will be open.
I’m also wondering if it’s waiting for for some Black Fri “deals” or shall I just pull the trigger?
Also cyber Monday coming up - not a sure what is best?
My guess is that meaningful deals are a lot more likely on tamzzy's spec than on my spec, because e.g. the CPU&GPU are higher value items to begin with, so a 10-15% discount on either of them amounts to a lot more than 10% on a £100 CPU.
