Hi guys,
Can you please help me connect all my internal wiring. The manual for both the case and motherboard are only about 75% useful. Half the stuff isn't explained anywhere that I can see, and seeing as this is my first build I don't really know where everything goes.
My motherboard is a MSi P67A-GD65; my case is a Cooler Master Storm Scout.
I no doubt have tons more questions. Mainly they are about the motherboard connector pins but any help with the above to get started would be great.
Thanks.
- The case has a SATA cable coming from somewhere (no idea where). What's it for and do I need to connect it? I have already connected the HDD and DVD drive with separate SATA cables to the motherboard.
- The motherboard came with a little packet of connector blocks. Not sure what they're for, and it doesn't really explain properly where they go on the motherboard. I know I need to connect the front panel wires to one of the blocks and then put the block on the motherboard connection JFP1 but it's not properly explained which wires go into which and which way round they should go (the block has + and - symbols but the wires have 'G' and a triangle... does G go into - or..?)
- My graphics card sits over the pins on the motherboard for the front panel wires... lol wut? How am I supposed to connect them?
- The front fan has a male molex connector with 2 pins. What do I plug it into? There's only 4-pin connectors from the power supply... is that fine?
- The case has 2 more molex connectors which presumably go to the top and back fans. However, the first is one wire which then has two 4-pin molex connectors (a M and F) at the end. I'm guessing this is the 140mm top fan. What do I plug these into, as the PSU doesn't have a 4-pin male connector.
The other is just a 2-pin male connector, which I guess is the back 120mm fan. Again, do I just plug this into a 4-pin from the PSU?
Thanks.
