LTMatt i just installed Accelero to my 7970, just take it slow and pray the pc boots up after its done! thats what i did.........
Lol, reading that is still not filling me with confidence.
Cheers for the advice guys, when I put the block on I tighten the screws very gently around the core and the whole block! Tho I did notice lot of themal paste around the circuit board! Can themal paste cause a short! I thought that stuff was non-conductive!
Thanks for help guys anyway, hope its not dead, but it seems that way!
One final thought, do those have a bios switch ?, You haven't by chance knocked it half way between settings ?
You should be OK mate as long as there is no physical damage to the card. I know someone who rma'd a MSI card after changing the thermal paste and adding a new cooler. Just replaced stock cooler and sent it off and got a replacement.
mSI seem pretty good about RMA's.
Don't know what you did wrong but good luck next time.
Also they can't check if it was over clocked.
Good luck bud![]()
