Please Help: New System build
11 Oct 2006
Hi all!
I'm building a new system and would like your advice as to weather everything I have chosen will work together alright and any other advice you might have.
This is what I have chosen so far :
Mobo
*MSI P4N SLI XE-F nForce4 SLI Intel LGA775 Serial ATA-300 8channel audio ATX 117018 15 in stock £53.10 £53.10
CPU
*Core 2 Duo E6300 1.86ghz - Skt775 Fsb1066 2mb Cache Boxed In 112704 402 in stock £107.40 £107.40
Memory
*competitor* 1GB DDR2 800 MHz PC2-6400 240pin Extra Value Ram 2 x 512 KIT 116355 10 in stock £80.57 £80.57
DVD RW
*Sony AW-G170AB2 18xDVD±RW/RAM Dual Layer Writer Black - Bare Drive 116255 340 in stock £17.01 £17.01
Monitor
*Belinea 1925S1W 19" Widescreen 5ms 850:1 (1440 X 900) Silver & Black MultiMedia TFT Monitor 3 Years Onsite Warranty 114209 91 in stock £109.99 £109.99
Case+PSU
*Sansun SN-C0503 Gaming Case in Silver with a 350w Power Suply and 2.0USB/Audio 086532 1 in stock £25.52 £25.52
HDD
*Western Digital WD2500KS Caviar SE 250GB 7200RPM SATA2/300 16MB Cache - OEM 094403 1429 in stock £43.95 £43.95
GPU
*Asus 7600GS SILENT 512MB DDR2 PCI-E 111199 98 in stock £76.00 £76.00
- remove item Cart Total: £577.36
Approx Cart Weight: 16.86Kg
SubTotal: £520.53
VAT: £91.13
Total: £611.66
Many thanks in advance ;-)
Hi there,
Im sure your motherboard will take the E6300 but i would look around and check first to see if someone else has a core 2 duo processor in that motherboard. It might only be a bios update.
Other than that, the rest of the stuff should work fine.
You may have a problem in that your motherboard doesn't officially support Conroe according to MSI.
I'd also suggest that the PSU supplied with the case is unlikely to be any good and finally the graphics card isn't particularly great, if that is around your budget save up a little bit more and get a 7600gt. :)
The graphics card is certainly compatible given it is PCI-E but I don't know if the CPU is.
The Gigabyte DS3 will probably be better for overclocking(read as 99% sure of this) but I suppose it depends on how far you might want to take the overclocks.
Yeah will def get atleast a 450w PSU.
Re: GPU
Which 7600GT would you recommend ?
The Belinea 1925S1W monitor doesn't support DVI as far as I know, so would need something with normal VGA connector ???
A 7600gt is pretty standard generally, some are pre-overclocked but there isn't a huge amount of point in spending more on them, I'd also not bother too much about getting any more than 256mb Ram onboard as a 19" monitor doesn't really require it. Just get the cheapest you can find. :)
They will either have a standard analogue connection for the monitor(D-Sub) or they should have a DVI-analogue adapter included.
Thanks for all you help so far Semi-pro waster, really good help.
I've made some changes now, hows this setup ??
I'm going to look around for the best prices though !
Core 2 Duo E6300 1.86ghz - Skt775 Fsb1066 2mb Cache Boxed In 112704 389 in stock £107.40 £107.40
Sony AW-G170AB2 18xDVD±RW/RAM Dual Layer Writer Black - Bare Drive 116255 203 in stock £17.01 £17.01
Western Digital WD2500KS Caviar SE 250GB 7200RPM SATA2/300 16MB Cache - OEM 094403 1393 in stock £43.95 £43.95
ASRock ConRoe945G-DVI i945G SKT LGA775 onboard VGA 8 channel audio mATX 119413 30 in stock £41.69 £41.69
*competitor* 2GB DDR2 667MHz PC2-5400 240pin Extra Value Ram 2 x 1GB KIT 116260 6 in stock £127.22 £127.22
Point Of View 7900GS 256MB 256bit GDDR3 PCI-E 115739 57 in stock £119.13 £119.13
Antec NSK6500 Black/Silver Super Mid Tower Case - With 430W PSU 114046 9 in stock £66.79 £66.79
Shipping Surcharge: £4.20
SubTotal: £642.27
VAT: £112.44
Total: £754.71
Is it better to get the CPU without the heat sink and buy one seperate ??
It looks good, I'd probably buy the CPU OEM and get a separate heatsink and fan but you do get a slightly shorter warranty(1 year compared to 3 years normally). Other than that I don't know anything about the Ram but it is probably just some generic stuff rebranded so should work fine. :)
You're speccing up parts from a competitor, a bit cheeky really considering this is the OCuk forums. Was clearly obvious when i saw the stock numbers next to the parts.
By listing parts from that site, you're mentioning a competitor (against forum rules).
Apologies, I was using *competitor*, but only cause its easier to see what you building, once I know what I want I will be ordering quite a lot of the stuff from OCuk. In furture I will only put the product name then if it bothers you so much. I just want o make it perfectly clear that I am not trying to get people to user other site or detract from buying from OCuk.
Cheers
WOuld I be bett off with an ATI GPU over the Nvidia, on my price range ?
was thinking of: Sapphire ATI Radeon X1950 Pro 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (GX-134-SP) --> £135.11 ????
for now buy a 6800 from a well know competitor for £40 then in a few months buy a lovely top of the range dx10 card....
to spend that much on a new gfx card now is just not worth it :)
ultimately your cash your choice :)
And spending £400 on a graphics card is a wise choice?.......
Bang for buck the DX9 card is money well spent if you ask me. DX10 cards are still gonna be at least £300+ in a few months for sure, plus we're yet to hear about bugs, driver issues, and ATI of course have their release coming up, but i still don't expect prices to plummit anytime soon.
So personally i'd say the 7900GS is a wiser investment.
how can spending xx hundred pounds for a few months be a wise choice?
in april when dx10 games are available the card u buy then will last a lot alonger then like 4 months
You won't need DX10 until you need VISTA, as i understand it and i could be wrong, DX10 is going to be Vista only.
Spending £100 or so pound for a card that will last you until DX10 is a requirement, not that will be anytime soon, is a good investment, better then spending £400 for a card, then waiting to buy Vista for £xxx to use it on DX10. Would it not be wiser to wait until you have to have Vista, then fork out on the card, rather then run a DX10 on DX9 and pay more for it now.
The card could easily come down £100 in the time it'll take for DX10 to become a requirement, so therefore it costs you no more in the long run, plus by that time you'll have more established and tested cards on the market to buy.
Buying the newest and greatest hardware is not always the best choice.
It depends on how you do it but essentially I'd agree with your post, DX10 is highly unlikely to be a requirement for a reasonable period because the user base of DX9 compatible cards is such that I'd be very surprised if there were more than a few games in the next 6-12 months that were DX10 only. Most games will be programmed for DX9 with DX10 extensions I'd think. :)
