Can you try the RAM in another system? Is it still doing the hiccuping with JUST the new RAM you ordered installed? Have you tried resetting the bios to "Load fail-safe defaults"?
While the problem could be the RAM, the issue is the motherboard could also be at fault due to something as simple as a faulty RAM socket or something as huge as the CPU failing.
