please help....really desperate
18 Oct 2002
glasgow
hi my son has just used musicmatch somehow to delete over 30 gigs of irreplaceable music from my f drive ,please please tell me somehow I can restore the f drive ?
I have two hard drives c and f and my operating system is xp pro
many thanks indeed
to anyone who can possibly help
Read the threads yes.. Noted!
Like always I would check using my nod32 anti virus protection..
I should have pointed that out but the submitter off the torrent is always very good ...
Try a programme called GetDatBackforNTFS Download ma trial, run and see what you can recover and if it is corrupted. You will need to buy the programme to recover the lost data but it well worth the money. Good luck.
You can use the free trial if you have enough space on the other hard drive. The free version won't restore to the original hard drive. But it will allow you to copy the files to another hard drive.
GetDataBack for NTFS has worked wonders for me before.
MIght be worth investing in another harddrive and backing upto that. It wont cost you much if it's only 30GB and much easier than backing upto cd/dvd.
hi guys
havent switched on my main pc since my disaster with my music, however I've just found the file in my f drive within my my music folder in a folder called recycler :)......................is there any way of undoing this recycler folder so that all the music tracks some 4600 odd about 32 gig worth go back into their empty album folders ie the who etc etc
many thanks indeed from a mightily relieved person
cheers
